'95 Xplorer 400 wont go into reverse
Old Sep 7, 2008 | 12:33 PM
hesborn2fly's Avatar
Default '95 Xplorer 400 wont go into reverse
This seems to be my last problem to solve before having this xplorer back in good rideing condition. It is grinding when you try to put it in reverse. It wont engage in reverse unless while trying to shift it you roll it back a little then it will engage. Going into foward high isnt nearly as bad but its not really smooth. It is idleing real nice but maybe slightly fast. Funny thing is when I go to adjust the idle needle on the carb nothing changes at all no matter how much its unscrewed. The linkages seem to be well adjusted. Any help would be appreciated.
Thanks
Old Sep 7, 2008 | 01:58 PM
LOOSEN slack at throttle cable adjuster to about 1/8" slack on thumb throttle,then can adjust idle speed at carb. Adjust idle speed to low steady idle and see if helps shifting.Transmission gears are straight cut gears,not beveled and idle speed affects shifting. IF doesnt help shifting,still grinding,could be internal problems. CAN try to readjust linkage: In NEUTRAL,loosen both lock nuts on linkage at shift box end,pull up adjusters,can turn out or in to where adjuster DROPS STRAIGHT IN SHIFTER BOX ARM. Do this on both linkage arms. Hope this helps
Old Sep 7, 2008 | 03:25 PM
Thanks for the info, I'll try the idle adjustment
MeadowlarkFarm
Nov 27, 2019 08:40 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
rockinkgin
Sep 25, 2015 01:52 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
