03' sp 500 h.o. smoking
Old Sep 7, 2008 | 11:21 PM
500H.O.'s Avatar
Default 03' sp 500 h.o. smoking
I noticed my quad smoking. The smoke is very white in color. I changed the oil and filter but no change in the smoking. Is there a drain plug on the engine for the oil or just on the jug? There is only 1100 miles on this machine, time for a overhaul already? ANY SUGGESTIONS??
Old Sep 7, 2008 | 11:30 PM
Sump drain plug on right side of engine that needs to be drained when doing oil changes. Holds about 8 ounces oil. IF never done or never cleaned tank strainer,OR wrong weight oil could be source of problem white smoking( oil burning) Plus is oil level high,also check air box for oily air filter,hopefully this your problem!
Old Sep 8, 2008 | 12:23 AM
500H.O.'s Avatar
Thanks - good info. What kind & wight of oil should i use?
Old Sep 8, 2008 | 01:12 AM
Either 0w-40 (Mobil 1 makes it, Polaris is phasing out their 0w-40) OR PS4 PLUS 2w-50 the new Polaris oil. DONT use 10w-30,10w-40,OR any other viscosity oil! YES I KNOW others have used and SWEAR by different oils and viscosity,BUT they dont experience the damage I see especially on the 500 engine from wrong oil and infrequent oil changes! PLUS there is a cleanout plug on muffler,but dont think will solve your problem. Keep us posted. Good luck
Old Sep 8, 2008 | 08:37 AM
500H.O.'s Avatar
I'll give it a try thanks for the info.
Old Sep 8, 2008 | 08:20 PM
500H.O.'s Avatar
do i just fill it up in the jug or do i need to put some in the engine to prevent a "dry start".
Old Sep 9, 2008 | 11:15 PM
Drain tank and sump plug,clean screen on oil tank fitting IF never done before.Put in 1 3/4 quarts plus new oil filter,top of oil tank is vent line,clamp 1" away from fitting with small vicegrips,run for a couple minutes,release pliers,hissing noise normal(this is to prime oil pump) then check/top off to full mark on dipstick screwed all the way in. Good luck
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
EIF
Apr 20, 2017 07:15 PM
CosmoM
Sep 21, 2015 04:57 PM
bvolks
Sep 13, 2015 12:57 PM
