polaris 6x6 tire size
Old Sep 10, 2008 | 10:41 PM
sportsman5006x6's Avatar
Default polaris 6x6 tire size
what is the largest size tires that i can put on my 2004 sportsman 500 6x6 whant to put more aggresive tires on maybe a little bit taller
Old Sep 11, 2008 | 08:55 AM
I think it is more dependent on the rears not scraping each other than anything. If you add an inch taller tire it will add 1/2 and inch of radius or ground clearance. How much room is there between the two tires? If it is 1 1/2 inches or less my guess would be you wouldn't want to go any bigger than stock. If there is enough room probably 26" tires are the max.
Old Mar 12, 2022 | 04:55 AM
LindeMan86's Avatar
I know it is an old thread but it is hard to find som god to read.
I have a 2003 6x6 and I need new tires. Ofc I want bigger and badder 😂
some say 26 some 27, but I don’t know if it is newer 6x6.
and god luck to find good tires in that size that also have for the 10” rear 😂
Cody_20
Mar 23, 2012 11:04 PM
mvvette97
Mar 30, 2006 05:50 PM
sparkys
Jan 5, 2002 06:19 PM
Brad_L
Feb 9, 2000 01:51 AM
