lakota crankcase pressure
Old Sep 11, 2008 | 08:54 PM
skj283's Avatar
Default lakota crankcase pressure
hey just got a 01 lakota, took the cap off the filler while it is running and it feels like it is blowing pressure out of it. i know at first thought your thinking that is stupid but i have never had one act like that before. checked the breather that comes out of the valve cover and it is breathing. just curious if this is just normal windage that i am feeling or if it is losing compression through the bottom end. it runs perfect, starts perfect, doesnt smoke, get hot or anything. oil splashing i understand but the air i dont. i havent done a compression test yet but just wanted to get some opinions.
thanks
Old Oct 16, 2008 | 10:11 AM
jeffeosso's Avatar
I don't know if it is normal, but both of mine do the same.. open it up, and it blows....
Old Oct 16, 2008 | 02:52 PM
skj283's Avatar
thanks, i thought that post was lost forever. it makes me feel a little better. i guess it is just windage. thanks again
Old Nov 9, 2008 | 09:08 PM
jeffeosso's Avatar
figured this one out.
There is ALOT of moving parts, not 5 inches from the oil filler. lots and lots of BIG pieces moving in and around a wet clutch...
i think the most pressure, while running with the oil filler open, is largely due to the primary clutch and back gears spinning ...
so, there is the answer, or at least where I see it since i replace my clutch and add HD springs
Alex G.
Sep 11, 2017 11:38 PM
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
2many2ride
Sep 27, 2015 04:35 AM
MPDano
1) Engine problems..
Sep 20, 2015 09:48 PM
