TrailBoss 250
Old Sep 12, 2008 | 10:43 AM
guzz1869's Avatar
Default TrailBoss 250
Hi, there! Anyone know what the override butten if for and what it does? How would I be able to tell, if it were engaged? I would sure appreciate the help.
Old Sep 12, 2008 | 10:51 AM
650Mobrute's Avatar
not 100% on that model of bike but most overide buttons are for a reverse speed limiter. If you dont push it that bike cuts out and wont go but 3-5 mph in reverse, hold it in and it opens up.
Like I said not 100% but that would be my first guess
Old Sep 12, 2008 | 10:52 AM
GunnSmoke's Avatar
that yellow button is the reverse overide switch, this gives you full throttle while in reverse, if you don't use the button it will hit a rev limiter causing it to spit and sputter. hope this helps
Old Sep 12, 2008 | 10:54 AM
MECHANIKE's Avatar
it allows you to go in reverse faster without retarding the engines timing,its a safety.be careful.you are more likely to tip over with the button pushed in.........
Old Sep 12, 2008 | 11:00 AM
guzz1869's Avatar
Thankyou for everyones help. I bought this 4 wheeler, and had to replace the shift fork cause it wouldnt go forward, now I got the tranny back, with a new shift fork in, now it dont have reverse, go figure. Didnt know if the over ride butten being engaged had anything to do with it or not, so thanks for the help
Old Sep 12, 2008 | 06:25 PM
blaster24's Avatar
its a reverse overide bike will go about 3-5mph until button is pushed then you get full power in reverse it is a safety!
Old Sep 12, 2008 | 11:03 PM
MagnumPO's Avatar
Its for flipping your bike over
Old Sep 13, 2008 | 01:04 AM
Tippmann98's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: MagnumPO
Its for flipping your bike over</end quote></div>
Exactly! I let my friend ride my 4-wheeler and it was his first time and I was mocking him by racing him in reverse. Let's just say I ended up on the ground, apart from the 4-wheeler.
68_327_c20
Nov 25, 2023 12:26 PM
Magistar
Apr 13, 2023 04:39 AM
Myronh
Sep 8, 2015 11:27 AM
binky79
Jul 30, 2015 06:37 PM
2000Polaris
Sep 13, 2000 10:22 PM
