need help on trailboss 250 r/es
Old Sep 13, 2008 | 01:52 AM
killdux's Avatar
Default need help on trailboss 250 r/es
ok, fellas i need a little info for a polaris atv. It is a 85 to 88 trailboss. It has 120 psi compression and holds it a couple of minutes before bleeding off pressure in the bottom end. Has 2 gallons 0f just bought premium gas and a brand new plug a bpr8es. I was told it ran fine till throttle cable broke and they could'nt get the exact one but the dealer sold them one to work . I have adjusted it where it is operating right plus i went through the carb and think that i have it right. Here is the problem i have . It will run on ether but when it runs out then it quits, and also it seems like it has to crank alot to hit and run too. Any ideas anyone?
Old Sep 13, 2008 | 12:40 PM
killdux's Avatar
bump
Old Sep 13, 2008 | 04:41 PM
killdux's Avatar
anybody have any ideas at all?
Old Sep 13, 2008 | 08:23 PM
IF starts on ether only ,THEN either still have carb problem or can even be bottom end compression (crank seals) even if have decent top end compression. Fire,fuel,air,compression, gota be one or the other. If done leakdown test and not holding like you say, seals could be problem. Also takes BR8ES not BPR8ES plug.
Old Sep 13, 2008 | 09:18 PM
killdux's Avatar
How would i ckeck the bottom end pressure and what should it be? Had a kawasaki jet ski once and was told it was ten in the bottom of them. The dealer sold me the bpr8es and said that it was it so i did'nt know better to contradict him or his book. I have a br8es and will change it though, looks to me like the only difference is the unshrouding of the bottom of the plug core.
Old Sep 13, 2008 | 10:56 PM
BPR8ES is an extended probe plug,sets deeper,not needed in 250 engine. IF have exhaust blockoff plug,plus carb adapter and pressure tester SHOULD hold 7 psi WITHOUT any leaking! (MUST use low pressure device such as bicycle pump) Can also spray soapy water around base gasket,carb manifold,plus crank seals to see if bubbling and leaking(if have stripped down to crank seals,replace anyway!!
Old Sep 14, 2008 | 12:22 AM
killdux's Avatar
Thanks for some info and i will give it a check and see and get back to you with results. Ihave pulled the carb back off and i am going over it again so i can make sure no problem there.
68_327_c20
Nov 25, 2023 12:26 PM
Magistar
Apr 13, 2023 04:39 AM
Myronh
Sep 8, 2015 11:27 AM
binky79
Jul 30, 2015 06:37 PM
TJM
Jun 11, 2015 01:28 PM
