660 raptor starting trouble
Old Sep 15, 2008 | 03:11 PM
wickedwayz83's Avatar
Default 660 raptor starting trouble
Aight... Ive got this 660 Raptor, edelbrock carb, Yoshimura full system, Big Gun rev box(CDI), L&A one way bearing, G-force axle, Elka shocks.... the thing is i cant get the damn thing to start with the starter. the motor turns over fine, I pulled the plug out and cranked it over and checked to see if it was firing and it is but it looked a little weak. If i pull start it it start fine and runs fine. I called the dealership and they told me the CDI box was probably goin bad so i bought the big gun one and still the same thing, I dont want to keep throwing parts at, so does anyone have a clue where to start. I was thinkin trying the stator or something next. Somebody please help, im about to pull my hair out... thanks in advance.
Old Sep 15, 2008 | 04:49 PM
raptorider's Avatar
did you say you can PULL start it?
have you hooked it up to a car battery yet to try and start it?
Old Sep 16, 2008 | 07:29 AM
Yea I can pull it with another quad or roll it off a hill or something and it will fire right up. And yea Ive hooked jumper cables to it from my truck and it just cranks over, no start, so that pretty much rules out a voltage problem unless the ignition system isnt getting enough for some reason. Could the coil be breaking down or weak or something? I've even tried using ether while cranking it over and it still wont fire. I dont really know alot about these newer 4 strokes, ive always had 2 stroke dirt bikes and a banshee, so i dont really know where to start to look.
Old Sep 21, 2008 | 09:23 PM
RaptorRYDR's Avatar
Have you checked your solenoid where the fuses are?
Old Sep 23, 2008 | 01:16 AM
RaptorRYDR's Avatar
Hey wicked, how do you like that CDI box? Does it really help anything out? I am trying to find a dynatek for my 01 Raptor but cant seem to find one so I was going to go with a procom one from what I understand big gun, procom and the other ones are the same thing with different stickers on them and I need one soon.. you are the first one that I seen with one so I thought I would ask..
by the way did you check the solenoid yet? try putting a screwdriver on the 2 screws on it with the key on and see what happens if it turns over that could well be your problem thats what I found with mine at one point.
Old Sep 24, 2008 | 10:14 PM
Spartan2551's Avatar
My Raptor 660 is having a kind of the same probelm. I cant get it to start.. the spare looks kind of weak when i was checking it out. I am almost about to try a new CDI box would like to see if their is a way to check it.
Old Sep 25, 2008 | 07:23 AM
I figured it out, the intake valves were way tight and not closing all the way... yea the big gun cdi seems like a pretty sweet unit, can't really tell if it helped or not cause I put it, the exhaust, and the carb on all at once.
tycobb
ATC 3-Wheelers
Oct 23, 2015 07:37 PM
AtvManiac78
Jul 11, 2015 03:20 AM
1000gade
May 27, 2015 12:37 PM
RaptorGuy01
Oct 31, 2000 04:23 AM
atving
Nov 17, 1999 09:24 PM
