2008 sportsman 800?
Old Sep 15, 2008 | 10:58 PM
badazzpred's Avatar
Default 2008 sportsman 800?
I thought I saw a post on here about some type of spacer kit for the stock front springs? Who makes them? and where do I find them?
What would be better the spacer kit? or an aftermarket coilspring set?
I noticed polaris sells a heavy duty set which are supposed to be better than the stockers true or false?
Thanks for any advice and help with this.
Old Sep 16, 2008 | 12:11 AM
500H.O.'s Avatar
I used pipe on my 03 sp . I think it was 2'' pvc. I first used a 2 1/2'' spacer but it was too much and it put the front axles in a bind so I went down to a 1 3/4'' and it's ok and I can clear 28's. I used a similar trick in the rear. Cost me about 5 bucks and 2 hours front and rear.
Old Sep 16, 2008 | 06:55 AM
user493's Avatar
Moto Psycho
You can get adjustable spacers for the front and rear from Polaris. You can set it to 0, 1/2, or 1 inch of extra lift (compression?).
Old Sep 16, 2008 | 05:33 PM
Indslpwr04's Avatar
500 H.O. Did your mod help with bottoming out and give extra load capacity?
Old Sep 16, 2008 | 06:46 PM
badazzpred's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: jumbofrank
You can get adjustable spacers for the front and rear from Polaris. You can set it to 0, 1/2, or 1 inch of extra lift (compression?).</end quote></div>
Do you think the spacers are a good idea or go to a different spring set?
I just trail ride and use the quad for hunting and around the house type stuff no mud bogging or racing. It just seems like turning the 08 sp800 when at slower speeds is tough as hell, I thought I saw somewhere on here that going the spacer route would help with the turning right or left making it a smoother to turn?
Old Sep 16, 2008 | 07:37 PM
Spdecat's Avatar
I put these on my 500 work great I ordered them from the Polaris dealer .
http://atvillustrated.com/node/431
Old Sep 16, 2008 | 10:08 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
<div class="FTQUOTE"><begin quote>Originally posted by: badazzpred
I just trail ride and use the quad for hunting and around the house type stuff no mud bogging or racing. It just seems like turning the 08 sp800 when at slower speeds is tough as hell, I thought I saw somewhere on here that going the spacer route would help with the turning right or left making it a smoother to turn?</end quote></div>
if it helps i put 1 1/2" cpvc spacers on my 06' to help the sagging front springs and had good luck w/ it. cheap fix for under $5.00. i would either do what i did or buy heavier front springs before i would buy the polaris adjustable ones. imo.
Old Sep 16, 2008 | 10:15 PM
badazzpred's Avatar
Hey stendori do you have any pics of the mod and how easy is it to install?
bzdok1234
30
Feb 23, 2016 01:55 PM
panicmanic
Aug 25, 2015 09:10 AM
velcro7279
Aug 24, 2015 01:15 PM
Donniereble
Aug 21, 2015 10:46 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
