need help with 700 sportsman carb.
i have a 2004 700 that when i get the front end going up a hill or if i go into a mudhole and one side drops off and cause's the side to lean over the carb flood's so bad that it will stall out or not even rev enough to pull. i have set the float level and it is correct. i have also taken it to my local polaris dealer and it is still the same. someone please help me out if possible. thanks
i've had similar problems, and I thought it was my carb. Not on the hills though. When I would get out of shape in a mud hole and the front would get up, I would lose power. I finally figured out that it was my exhaust would get clogged and I would loose power.
