trikezilla?
Old Sep 17, 2008 | 03:03 AM
this guy's Avatar
Default trikezilla?
I am a Diehard fan of 3 wheelers and quadzillas, actaully any sport machine from the 80's is great for me, which leads to my situation. When I bought my zilla it came with an extra engine with low hours and in great shape. I would love to build a 3 wheeler frame around this wonderful powerplant. Are there any frame builders left out there who have a clue as to how to make trike frames? Now a friend of mine and I have solved the front suspension issues for most trikes by (this is still in process on another project) making fatter clamps to hold the fat inverted forks off of 85cc MX bikes. I would like to make it as OEM as possible (full floater suspension, t-back seat, and hardware). Any input would be helpful, I think this would be great MX track and fast desert fun.
Old Sep 18, 2008 | 01:15 AM
SMFREY's Avatar
Default trikezilla?
I would start by looking at a three wheeler already built with good suspension made to handle power
Possibly look for a 250R with wasted engine or a 350X same
Easier to modify these
Good luck
Ray
Old Sep 18, 2008 | 02:56 AM
this guy's Avatar
Default trikezilla?
I considered that, but they are simply too small and have flaws that would only be magnified by the massive power output. We've all seen the KX/CR 500 powered trikes and they are always hill shooters, for this project to work tis frame is in many ways have to be like the quad it came out of, long wide and in general very large, but light. I'm pencilling up drawing in my spare time the more I do the more the rear end looks like a zilla with a +2 swingarm.
Old Sep 20, 2008 | 04:22 PM
Black Sheep's Avatar
Default trikezilla?
<div class="FTQUOTE"><begin quote>Originally posted by: this guy
Are there any frame builders left out there who have a clue as to how to make trike frames? </end quote></div>
I guess you missed this thread..........
http://forums.atvconnection.co...tid/15/threadid/550616
Old Sep 21, 2008 | 04:21 PM
this guy's Avatar
Default trikezilla?
Wow, that is some incredible work!!!!!!!
Old Sep 21, 2008 | 06:06 PM
Default trikezilla?
thank you. i could easily convert your zilla and use almost all suzuki parts
Old Sep 21, 2008 | 07:32 PM
this guy's Avatar
Default trikezilla?
where are you located out of?
Old Sep 21, 2008 | 07:59 PM
Default trikezilla?
upstate NY sorry link won't work. I'll pm you my number
Old Sep 23, 2008 | 03:18 AM
this guy's Avatar
Default trikezilla?
as far as the front suspension goes, what did you use and what kind of triple clamps did you use? Any idea what your 450 weighs?
Old Sep 23, 2008 | 04:48 AM
Default trikezilla?
The front Forks are 06 Showa 47mm the same ones that come on the 06 CRF 450R. I modified them to 11" travel (-1" from CRF)
The triple clamps are my design built by a private triple clamp manufacture. ( He builds clamps for severall pro race teams and riders ) I actually have two differant designs avalible. The differance is the fork off set from the stem. Basically i can put the forks in two positions by 1 1/2" front to back. this allows a differant weight bias for differant conditions/set ups. I will be designing others as well. I can also build triples to suit each conversion i do.
The weight of my trike varies with parts installed. The pictures you see is the my personal MX set up. I have differant Axles/Swingarms/Shocks/Wheels/Pipes Ect. that alter the weight But the Base starting weight with all stock TRX parts,... ie swingarm/pipe ect,...is 315lbs. Less then a 350X but more then a 250R.
