No Sleeve 720??
Old Sep 17, 2008 | 07:32 PM
NateB's Avatar
Default No Sleeve 720??
I'm plannin on goin big bore this winter and i have been researching all of the kits. and i am curious why you can't bore and replate to a 105mm without a sleeve. i think i read in a post that ERBE has done this. i am assuming the sleeve makes it stronger, wether made from steel or aluminum. So what i would really like to know is what are the limits to that setup? Should i try it?
Old Sep 17, 2008 | 07:52 PM
SANDMAN430's Avatar
no one could ever get a head gasket to seal. CT racing did that mod for a short while.
SANDMAN430's Avatar
they did get a 102mm to work.
Old Sep 17, 2008 | 07:53 PM
NateB's Avatar
i dont understand why tho. it is the same thickness head sealing surface as the steel sleeve 720.
Old Sep 18, 2008 | 02:40 AM
SANDMAN430's Avatar
maybe you can get it to work, lots couldn't. seems the sleeve took some of the water jacket space if I recall right, not much but some
Old Sep 20, 2008 | 01:53 PM
ERBEDS650's Avatar
Mine sealed fine with a Cometic Gasket. I only ran Gas no Nos
Old Sep 20, 2008 | 02:48 PM
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
<div class="FTQUOTE"><begin quote>Originally posted by: ERBEDS650
Mine sealed fine with a Cometic Gasket. I only ran Gas no Nos</end quote></div>
I'm hoping!!!
Old Sep 20, 2008 | 02:49 PM
ERBEDS650's Avatar
with a 13 to 1 compression piston!!!
Old Sep 20, 2008 | 05:42 PM
SANDMAN430's Avatar
thought you were the one with the aluminum sleeve not a bore of the stock cylinder
Old Sep 20, 2008 | 05:55 PM
ERBEDS650's Avatar
damn your right!! ill shut up now, ask scooby he was running one with turbo
