Baja 90 won't start
Old Sep 19, 2008 | 07:53 PM
Deven2208's Avatar
Default Baja 90 won't start
I purchased a 2006 baja 90cc atv last night at an auction. I only paid $300 for it and it looks to be in very good shape. However, once I got it home I found that it would not start. I am not getting a spark coming from the plug.. There are a few wires that are not connected and I don't see any place to connect them. Has anyone else experienced these problems or does anyone have any suggestions??
Thanks,
Deven
Old Sep 19, 2008 | 08:23 PM
luvmysxs's Avatar
don't want to bust you bubble but $300 isn't a deal for a 2 year old chinese 90 that doesn't run, now as far as extra wiring, don't worry about it, these chinese quads use a universal wiring harness, so sometimes depending on the quad, all the terimals may or may not be used, so you already check spark, now it's eaither a plugged carburetor because it was sitting awhile or it needs the valves adjusted. start by taking off the air cleaner and then taking very little starting fluid and spraying it directly into the carburetor while having the thottle open all the way, then close the thottle while trying to start quad, if it only a dirty carb then it should start for a second or two, if it the valves being to tight it still shouldn't start. if you need intructions on the valve adjustment or any other questions e-mail me luvmysxs@yahoo.com and i'll send you them
Bleach
1) Engine problems..
16
May 16, 2021 08:23 AM
Jun 15, 2015 11:22 PM
JackTheKing
Jun 14, 2015 03:04 PM
Jun 8, 2015 06:45 PM
1000gade
May 27, 2015 12:37 PM
