06 grizz- electric start going?
Old Sep 24, 2008 | 01:54 AM
Grizzybear's Avatar
Default 06 grizz- electric start going?
hey fellas, got an issue with my 06 grizzly. try to fire it up and alls i hear is "clickin" then once in awhile it will start. better is good, cleaned connections on positive and negative. Sounds coming from the first little module box (relay?) in the fuse compartment under hood. The little box (relay?) has 2 30A fuses on it and red cable from battery goes directly to this. cleaned connectors on this aswell.
Is this box shot possibly? anyone know what its called so i can look for one?
thanks,
Rob
Old Sep 24, 2008 | 09:19 AM
cadillacdude1975's Avatar
are you 100% positive that your battery is fully charged? this leads to more problems of the same description than i can count. if you do not know about the charge condition, get some jumper cables and hook them to a car and the quad's battery and see if it starts.
i am not sure on exact numbers, but i believe that the higher the engine is revved, the voltage should rise as well.
Old Sep 24, 2008 | 03:05 PM
Grizzybear's Avatar
ill pull out the ol multimeter and check the voltage.
4xrider
Apr 10, 2017 01:36 PM
Mikes350X
Nov 20, 2000 04:04 PM
rmx251
Sep 10, 2000 11:40 PM
Dom
Aug 3, 2000 08:04 PM
4trax300ex
Jul 29, 2000 11:41 AM
