2002 Big Bear Spudder at Mid RPM range
Old Sep 27, 2008 | 01:08 AM
Jeepsterbrad's Avatar
Default 2002 Big Bear Spudder at Mid RPM range
My big bear has had a slight spudder in the mid rpm range after I put my dynojet kit into it. Would this be because it is set too lean or too rich on the needle? also wondering if the pilot screw has anything to do with midrange rpm?
2 question, does anyone else's big bear have a pretty good valve tap? I checked my valves and they were good but the engine was cold, i know some bikes need to be checked warm, anyone know when it should be checked?
any info would be greatly appreciated
Old Sep 27, 2008 | 01:31 AM
the plug looks pretty normal is whats got me puzzled
Old Sep 27, 2008 | 05:40 AM
cadillacdude1975's Avatar
what came in the dynojet kit? i have heard that if you rejet the carb, you need to replace the factory pipe with a matched pipe for your new jet settings.
Old Sep 27, 2008 | 11:38 AM
i replaced the needle, spring, main jet (only the next size larger than stock). when adjusting the pilot screw, does tightening it increase or decrease how rich it is?
Old Sep 27, 2008 | 05:49 PM
any suggestions?
Old Sep 28, 2008 | 03:29 PM
i bet you will have to change the pipe now. that is what i have always heard. any alteration of the factory setting changes everything.
Old Sep 28, 2008 | 08:51 PM
i actually drilled out the main jet slightly and it runs awesome now, i when i put the kit in i put too small of a jet and it was choking for fuel. It was definitely strange how it only spuddered in middle rpm but the main jet was definitely the cause, thanks for all the help
wendal
Aug 3, 2024 10:03 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
atvcollector
Sep 8, 2015 05:11 PM
byronman
Sep 6, 2015 06:34 PM
Elkaholic
Sep 6, 2015 02:44 PM
