Rincon steering ?
Old Sep 30, 2008 | 07:02 PM
Schickie's Avatar
Default Rincon steering ?
'07 680 Rincon with less than 100 hours on it has some side to side play in the steering.
About 1.5 to 2 inches of wiggle at the bars. Everything looks tight with no noticable play in the tie rod ends.
Anyone else have this anomoly in an otherwise fantastic machine?
Old Sep 30, 2008 | 11:38 PM
MossyoakMudslinger's Avatar
Seeing how you helped me out on the tires i'll give you a clue, if you dont have any play in the tie rod end check your wheel bearings they may have a little rust or wear which will make it a little loose.
Old Oct 1, 2008 | 02:13 PM
JeffinTD's Avatar
You need to have someone wiggle the bar while you look to see what it is that has slop.
At the bottom of the steering stem is a nut that holds the plate that the inner tie rods attach to. That nut has been known to come loose on a variety of Hondas.
If it is loose, take the nut all the way off, clean both thread, and hit it with some locktite. I believe there is a cotter pin that you will have to take off the shaft to get the nut off. Be sure to put the pin back when done.
The other thing you could look at is the bolts that clamp down the steering shaft.
You might also check the lock nuts on the tie rod ends. Mine came loose on my first ride...
Old Oct 4, 2008 | 09:55 AM
Schickie's Avatar
Thanks, Guys. I'm gonna work on it today. We'll see.
Old Oct 14, 2008 | 08:10 PM
Schickie's Avatar
Yep! Big 3/4" nut at the bottom of the steering shaft was loose. So much for the assembly team. I'll' just go through it and tighten everything.
Old Oct 14, 2008 | 08:58 PM
JeffinTD's Avatar
Do take it off, and hit it with some cleaner, and some lock-tite...
Old Oct 16, 2008 | 07:26 PM
Schickie's Avatar
Gotcha Jeffin. Thanks!
Sep 30, 2015 01:37 AM
35dodge
Sep 29, 2015 09:40 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Logan Collins
Sep 5, 2015 08:03 PM
