TRX 450er Won't Start When Hot
Old Oct 1, 2008 | 03:48 PM
Quad Father's Avatar
Default TRX 450er Won't Start When Hot
I have an 06 TRX450er, it starts perfectly when cold, but after it heats up, if I stall it or turn it off it will not restart. I can bump start it and it will start or if I wait about 20-30 minutes to let it cool down then it will start again but it will not start with the electric starter. It has been to my mechanic and he can't figure it out either. He is a former Honda factory mechanic who really knows his stuff and still can't figure out the problem. He has adjusted the valves and says that they are perfect; he has checked the automatic decompressor and says that it is fine. The problem started after he changed the top end (new piston/rings, valves...) but he has triple checked everything and now we don't know what direction to go. I know some of you have probably had the same problem, so help me out!
I don't think that is the stator, because it still starts when bumping it
I don't think it is my ignition, because it still starts when bumping it
I don't think it is my starter because its still turns over, it just won't fire
I have a brand new battery
What else can it be???????
Old Oct 1, 2008 | 04:38 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
If I touch the throtle at all on a hot start, it floods out and will be almost impossible to start. Might be your problem too???
Old Oct 1, 2008 | 07:08 PM
I'll check it out.
Thanks!
Old Oct 1, 2008 | 11:03 PM
Red Rider
Don't touch the throtle before, after, or during a hot start...give it a try!
Your sig says "Baja Ready". Got any pics???? Where do you ride???
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
