sprocket changing
Old Oct 3, 2008 | 11:03 PM
junk belly's Avatar
Default sprocket changing
Thinking of changing from a stock 35 tooth sprocket to a 33 tooth sprocket. Or a 35 tooth to a 37 tooth (rear sprockets). How will these changes effect the performence on a polairs outlaw 90. I weigh about 145 and race hare scrambles
Old Oct 4, 2008 | 12:29 AM
slightly faster on smaller sprocket,slightly slower on larger sprocket with a little better pulling power.
Old Oct 5, 2008 | 11:14 PM
junk belly's Avatar
Will the smaller sprocket effect low end or take off? How much speed will i lose with the larger sprocket? thank you
Old Oct 6, 2008 | 09:22 AM
On a 90 you wont notice much difference either way. Not trying to discourage you,but the old saying is no replacement for displacement! If it was a larger displacement engine then you could notice an appreciable change,but you are dealing with a small out put engine and regearing will only make a slight difference either way. Good luck
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
merryman
Sep 19, 2015 03:15 AM
Canamaniac!
Sep 15, 2015 06:19 PM
bigbear350quad
Sep 11, 2015 12:40 PM
Jason Campbell
Sep 7, 2015 02:25 PM
