Electrical problem 04 500HO
Old Oct 14, 2008 | 04:34 PM
twister500's Avatar
Default Electrical problem 04 500HO
04 500 HO. While riding the battery light came on flashing. The headlights were on and the light would flash when the fan came on and it would stop if I turned the lights off. I replaced the battery due to it being about 3 years old. The charging rate is about 12.5-13.1 volts I think it's a little low. When this was new I had a problem under the front cowl some wires on the regulator were pulled tight and I moved them so they had slack. So I guess my question is do you think it might be the regulator or the stator?
Thanx!
Old Oct 14, 2008 | 06:26 PM
eggenz7's Avatar
the 12 to 13 volts is normal at idle. after about 1/4 throttle it should jump up to about 14.5 to 15.5 volts
Old Oct 14, 2008 | 08:02 PM
twister500's Avatar
Thats all it's putting out at about 4500-5000 rpms.
Old Oct 14, 2008 | 08:19 PM
eggenz7's Avatar
check to make sure there isnt any rust on the flywheel magnets. take some fine emory cloth and sand the magnets and the stator windings lightly to remove any rust. dont want to do it to much because it would change the spacing and reduce the output even more.
Old Oct 15, 2008 | 01:27 PM
twister500's Avatar
Think I got it. I pulled the front cover and found the voltage regulator was hot when running I removed the screws and pulled it out and found a hole burned threw the housing after moving the wires it would jump up to 14.5 volts and then back down to 12.4 volt so I ordered a new regulator (BIG $$$$$$$$$$) and will put it back in when I get it.
Old Oct 16, 2008 | 11:32 AM
Deerkiller's Avatar
Twister,
What does the voltage regulator look like? what is it mounted near? How is it identified.
Is there a part number on it?
Thanks, for future reference.
Deerkiller
Old Oct 16, 2008 | 11:45 AM
twister500's Avatar
It's mounted on a cross bar in front of the radiator. You need to remove the front rack and cowl/cover and it's black with a silver mounting bracket held in with two torx screws. Mine has 4 wires red, black, yellow, and yellow with a red stripe.
Old Oct 16, 2008 | 11:48 AM
TLC's Avatar
TLC
I think Polaris uses the term "Controller Module" there about $115!
http://216.37.204.206/wps/Pola...asp?Type=13&A=341&B=17
#29 I think.
Old Oct 16, 2008 | 05:28 PM
twister500's Avatar
I got mine from cheap cycle dot com $90.24 with shipping all of the dealers around me were $ 109.00-124.00 no discount even from the dealer I got three machines from. It's still alot of money but it pays to look around.
Old Oct 17, 2008 | 09:09 AM
Deerkiller's Avatar
If it's the same as an ECM I had to change one too. Some had a recall, Mine was not included. There are a lot of different problems caused by the bad one's. I paid $125.00.
Deerkiller
