Beartracker 250 Snorkel
Is there such a critter??? A firend has a 250 beartracker that damn near goes through anything. It is limited my the air intake, he wants to put a snorkel on it and I can;t find one online. ANY SUGGESTIONS???????
Home depot all the way, even if you do find a kit they are way overpriced compared to buying some PVC. I did my snorkel for around $20. Just look at where you want the intake to run and run the largest PVC that can fit into your air box so theres no air restriction
yea, i run my carb vent, crankcase vent, and rear differential vent up to the hight of the snorkel too. Just use PVC glue to connect the pipe for the air intake and make sure its sealed up. If you wanna run real deep put some dialectic grease on the spark plug and inside the cap to keep the connection from getting water in it.
Customer Service #1
May 15, 2020 08:46 AM
Steeldon
Sep 9, 2015 09:38 AM
Cantbuytime
Aug 17, 2015 06:33 PM
04, 250, bear, beartracker, carburetor, differential, kit, parts, pipe, rear, snorkel, snorkle, tracker, water, yamaha
