MY winch is not holding its tension.. help ...
ok i have a 3000 lbs gorrilla winch.. and like people that use there winch to stap down on the trailer.. well when i do tht and bring the tension on it just backs off and rolls back.. anyone know what part that would be or whats wrong with it...
welcome to my world
I called gorilla and I had to replace the end set of gears, the next time I used it, same thing, so i replaced them again, then it did it again and I sent it back and they sent me a new one, and I haven't used it
it was a big pain in my a$$
I should have bought a Warn in the beginning
they sent me all the parts and a call tag and stuff all for free, but it got old
These winches are not made for holding a load and you should never use it to secure your wheeler to a trailer. They are only for pulling a load and then to be released, not for holding a load.
<div class="FTQUOTE"><begin quote>Originally posted by: CaptainQuint
Probably nothing wrong with it. It has dynamic braking instead of mechanical so it isn't designed to hold tension like that.</end quote></div>
that is correct. that is why i wanted on eon my warn but the dealer screwed up(big suprise) when he oreded it for me but there more money for sure. p.s ive used my warn winch to hold down my wheelers for years w/out any issues. your not to suppose to bottom out your suspenion when cranking it down anyways so there shouldnt be that much stress on it. imo.
i am with stendori on this one as usual..i have secured my popo with my warn ci 2500 for years now and it has never failed me...if i ever need a new on it will be another warn..to secure i usualy chain the rear through my rear shackle and put in N and pull it tight up frt with the good ole warn..never any issues..is it recomended, no , will it be fine,good enuff for me
+1. The owners manual on a few of my winches said you're never supposed to use it to tie down the ATV, so I don't. No problem. That's what tie-down straps are made for. And they're a lot cheaper to replace than a winch when they break.
imo. if you have that much tention on holding downthe wheeler there is something really wrong. winches would have a hard time holding a heavy load right straight ahead, but holding a wheeler down shouldnt be an issue unless the winch is junk. imo.
its not recomended to swim after eating, take more the 2 asprin,drive with one hand, go more then 3000 on a oil change, drink hot coffe and the NOT recmoned list goes on..DAMN, this coffe is hot...lol
I've never used the winch to secure the machine to the trailer,but have to agree that it shouldn't cause a problem. But if the Gorrilla doesn't hold tension then I guess it wouldn't work for that. Even in normal winching situations you need it to hold tension sometimes, at least temporarily. Winchs have a duty cycle so you when pulling a heavy load,such as pulling someone out of a mudhole, you have to give it a break, and bumping the winch so to speak sometimes,if the winch didn't hold tension the line would loosen and eventually foul the cable on the drum.
Like said above you don't need to pull it real tight,just snug. Heck my 3500# Polaris would bottom the front suspension, lift the rear wheels easily and hold them there forever if I wanted it to,lol.. Reason I don't use it as a tie down is if you look at how the winch is mounted I didn't like pulling on the winch at such an angle,probably doesn't hurt anything but I choose not to. Besides I want most of the security in the rear keeping the machine from flying forward when I have to nail the brakes because some idiot pulled out in front of me.
