Need advice on a Honda 300 that I bought.Help please !
Old Oct 19, 2008 | 01:40 PM
Southerndude's Avatar
Default Need advice on a Honda 300 that I bought.Help please !
I bought a 1993 honda 300 4X4 yesterday so I could have something to deer hunt off of and when I got it home and went to unload it I seen it was leaking oil.I checked the plug and it felt lose so when i tried to tighten it the oil would poor so I stood the 4wheeler up and took out the plug and were the plug goes it is cracked.There 2 cracks there right were the plug screws in and one is tiny and the other is about half inch long and all of the threads is gone were the plug goes in.One of the cracks kinda runs into the motor casing a little bit also.I went back to the dude i bought it from and he swore up and down that he had no ideal that was like that and he would not give me any of my money back to help fix it.Now I'm out $1,275 and stuck with 4 wheeler that I can't really drive.My question is how would i get this fixed ?? I was told the motor would half to be tore down to get it and have it welded back but this is going to cost me about another $400 that I really can't afford.Any advice please let me hear it.Thanks!
Old Oct 19, 2008 | 10:11 PM
1130all's Avatar
just get a tap that is coarse thread and tap it out and get a bolt to fit the hole .then jb weld the cracks and that will last a longtime .i had the same problem thats what i did and it is still going today .that was 2 years ago.
Old Oct 19, 2008 | 10:57 PM
Was yours cracked in the drain hole ?? Mine has 2 tiny cracks and one runs into the case a little bit.There not real big crack at all.I thought JB weld but everyone has told me that it won't last.
Can jbweld take the heat from that spot ?? I read jbweld is only 250 good up to 250 degrees .Not sure how how it gets down there.
So you think I'll be good doing what you say ?
Old Oct 20, 2008 | 11:04 PM
1130all's Avatar
yell you will be good .just ruff it up a bit before you put the jb weld on
Old Oct 21, 2008 | 08:02 AM
Only1Stegall's Avatar
the case is aluminum you could always have it welded up and re tap the threads. good luck
Old Oct 21, 2008 | 08:41 PM
trx300man's Avatar
I tried this on a honda 90 engine and the cracks only got worse. A machinist friend of mine told me that I should have drilled a very small hole into the case at the end of each crack so it cannot crack further. Said otherwise it would prob keep cracking, which it did. The jb weld did not stop the leaking but it did slow it down.
Old Oct 22, 2008 | 08:10 AM
durabostbay's Avatar
a good jb weld job should stop the oil leak, at least it did for me on a suzuki 300 I used to own. But if it keeps cracking that would be another issue, drilling the small hole at the end of the crack is a trick that works well, and one you might want to consider then just jb the heck out of it.
Old Oct 22, 2008 | 08:49 PM
700 sportsman's Avatar
yeh I think the hole on the end is a good idea
Old Oct 25, 2008 | 01:56 PM
Y2daT's Avatar
yea the hole trick works on craked fenders as well
Polaris5
Aug 29, 2015 09:11 PM
heath legg
Jul 24, 2015 01:01 PM
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
Scottma518
Jul 10, 2015 12:42 AM
