Belt Light
Old Oct 21, 2008 | 07:32 PM
god2u's Avatar
Default Belt Light
I have a Kawasaki Prairie V-Twin 700 K-EBC and the belt light started flashing and I checked the belt and there is nothing wrong with the belt is there a reset and where can I go to find out how to fix. Thanks
Old Oct 21, 2008 | 09:48 PM
god2u's Avatar
Default Belt Light
I have checked the belt tension and the switch inside the clutch cover and still no luck. I don't know what I should do please help.
Old Oct 22, 2008 | 12:44 PM
Hayashi's Avatar
Default Belt Light
<div class="FTQUOTE"><begin quote>Originally posted by: god2u
I have checked the belt tension and the switch inside the clutch cover and still no luck. I don't know what I should do please help.</end quote></div>
What was the belt tension set at?
What position was the switch at ON or OFF?
Old Oct 22, 2008 | 07:33 PM
god2u's Avatar
Default Belt Light
I did visual check the belt and it not seem loose at all it had very little play maybe 1/8 to an 1/4 inch of play. I assumed that would be great but hey what do they say assumed it is usualy wrong. But as far as the switch it was i guess you would call it off it was facing the rear of the wheeler and I once again guess that is correct because I tried changeing it to on and still no change on the belt light flashing.
Old Oct 22, 2008 | 07:46 PM
god2u's Avatar
Default Belt Light
It is a 2003 model by the way
Old Oct 22, 2008 | 07:58 PM
Hayashi's Avatar
Default Belt Light
Belt tension & deflection amount: Spec is 22 to 27 mm when applying 14 lbs of force in the middle.
Switch is normally at ON position.
Your belt hit it to OFF position.
Just flipping the switch will NOT shut off the flashing belt light.
&gt; You need a new belt or adust the tension to reduce the belt deflection.
&gt; Then you MUST do the belt light cancelling procedure in addition to flipping the belt switch to ON position. Do a search and you will find a ton of info.
Get a manual.
panicmanic
Sep 28, 2015 12:59 PM
MooseHenden
Family ATVing Photos
Sep 20, 2015 04:14 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
