polaris outlaw electrical?
Old Oct 21, 2008 | 11:06 PM
lcooper1985's Avatar
Default polaris outlaw electrical?
2006 polaris outlaw im having a problem with it sparking consistanly, it will only spark if i leave it sit for about 20 mins , than when it does spark it only does about 5 rotations and its done. i have checked the resistance ine the coil and its ok. than i checked the power going to the coil from the CDI as i turned it over and its not continuous. is it the CDI ?, the stator?, or the ignition trigger? please give me some ideas and ask me more questions if you dont understand, thanks .
Old Oct 21, 2008 | 11:16 PM
eggenz7's Avatar
sounds like maybe the starter is taking too much juice from the system to send enough to the spark plug. try hooking a charger up to your battery then try it. if the battery is going bad it could have enough juice in it for a second and too then the starter drains it too fast.
Old Oct 21, 2008 | 11:21 PM
thanks for the idea i have tried the charger idea, its doing the same thing. but i will look in to getting a new battery. if you have any other ideas let me know thanks
Old Oct 21, 2008 | 11:24 PM
eggenz7's Avatar
try going through all the grounds and making sure they are clean. take all connectors loose and spray with contact cleaner then spray with dielectric grease. could be a simple short somewhere who knows. electrical issues are the hardest thing to trace.
Old Oct 22, 2008 | 07:10 PM
thanks man for responding with my ?'s
skinnyr6
Aug 25, 2023 02:18 AM
TheHood
Jul 26, 2015 09:51 AM
chammerbeck
Jul 17, 2015 08:06 AM
Unzzy66
Jul 11, 2015 10:01 PM
Chocobamofo
Jul 10, 2015 07:46 PM
