Warrior again >_>
Old Oct 23, 2008 | 08:43 PM
97YamahaWarrior's Avatar
Default Warrior again >_>
Its not charging its battery or something, like ill ride it for 2 days or so and then go to start it and it wont crank. Then i jump it off with my car and it starts right up again. Is there an alternator or something that is bad?
Old Oct 23, 2008 | 10:12 PM
zz8t's Avatar
your battery is bad (i think) jumping it off the car is not a good idea the car battery has way to much power
Old Oct 24, 2008 | 01:05 AM
Raptor450's Avatar
We've been through this one time on here, but jumping your ATV or lawn mower battery from a car will not hurt anything. It's the same voltage and yeah, the car has way more amperage but the ATV will only take the power that it needs.
Old Oct 24, 2008 | 04:07 AM
Andrew's Avatar
yea i jump mine all the time and the battery is fine
Old Oct 25, 2008 | 07:08 PM
Now jumping it will not charge the battery, any advise?
Old Oct 26, 2008 | 06:36 PM
Andrew's Avatar
buy some acid and charge it
Old Oct 27, 2008 | 10:22 AM
DOCPHIL's Avatar
THE FIRST THING YOU SHOULD DO IS CHARGE THE BATTERY (WITH A CHARGER)THEN USING A VOLT METER CHECK THE VOLTAGE WITH THE WHEELER OFF IT SHOULD BE 12.5 TO 13 VOLTS THEN START THE MACHINE AND BRING THE RPM OFF IDLE THE VOLT METER SHOULD BE MORE THAN 13 IF IT IS THEN THE BATTERY IS CHARGING. IF IT ISNT THEN CHECK THE CONNECTIONS ON THE 3 WHITE WIRES COMING OUT OF THE STATOR ON THE LEFT SIDE THE CONNECTORS ARE LOCATED BEHIND PLASTICS ON FRAME NEXT TO AIRFILTER. CLEAN THEM AND CHECK FOR WORN THROUGH WIRES.
Old Oct 27, 2008 | 09:43 PM
ATV24/7's Avatar
Does it make a tick tick tick when it is "dead"? If so it is the starter clutches. That happened to my warrior, i though it was the battery and changed it and it was starter clutches.
Old Oct 28, 2008 | 01:38 AM
If you mean the round thing that the positive and negative wires bolt to ive already replaced that not to long ago. Ive tried to read the voltage with a meter but its just showing 0.00. I think the battery is just completely dead.
Old Oct 28, 2008 | 09:50 PM
ATV24/7's Avatar
No the starter clutxhes are internal.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
