Removing 300ex headlight
I want to remove my headlight.. Are there any tricks or techniques that work beter then others !!! I am assuming there is a wire harness the just unplugs the light assy !!! Is this correct ?? Could you give me a brief description of the directions to do this !! i need to remove and for it too remain in working condition !! Also.. The neutral and reverse lights will be coming off also.. Will this cause any problems in the operation off the quad ???
thanks for all the help !!!
Jason
Jason
The headlight, reverse light and neutral light are all simple plugs. You don't hurt anything by dis-connecting them. Just make sure too seal all of the plugs up tight so that dirt and water does not cause trouble down the road.
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
