08 Sportsman 800 Wiring Question
Old Nov 2, 2008 | 10:42 AM
Lt CHEG's Avatar
Default 08 Sportsman 800 Wiring Question
I was looking more closely at my 08 Sportsman 800 yesterday after I washed it post ride. I will be adding a Warn winch to it soon and will install it myself. I looked at the wires by the headlight pod to see if I could find the red wire with white line that is referred to in the Warn winch install thread. I actually found 2 groups of wires. One has just a single red wire with white stripe terminated in a hard plastic female receptacle. The other setup has two red wires with white stripes terminated into one soft rubber termination. It looks like that setup is also a pre wired setup for something too. My question is which red wire with white stripe is the one that goes to the winch contactor? Also what is the other wire for? Handwarmers maybe? Thanks for the input.
Old Nov 2, 2008 | 11:52 AM
Use the hard plastic connector for the winch. Can use the other wires if adding other optional equipment by just peeling back rubber coating
Old Nov 2, 2008 | 03:31 PM
Lt CHEG's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: old polaris tech
Use the hard plastic connector for the winch. Can use the other wires if adding other optional equipment by just peeling back rubber coating</end quote></div>
Outstanding. Thank you.
SOLOLUCKY
Oct 4, 2024 09:09 PM
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
DOC HOLIDAY
Jun 15, 2015 05:00 PM
elpayaso
Jun 3, 2015 10:39 AM
