Rough running 700
Old Nov 3, 2008 | 12:51 AM
bsan1827's Avatar
Default Rough running 700
We went for a ride today and my machine seemed to really lag and lost power whenever I cracked the throttle. My air filter was really dirty, could this be the problem or should I be looking elsewhere?
Old Nov 3, 2008 | 07:09 AM
700 sportsman's Avatar
I would clean carb and check out the float levels too
Old Nov 3, 2008 | 07:17 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
the air filter could make it run that way if it was being blocked from air somewhat. check to make sure the carb boot isnt cracked as well as some had these issues.
Old Nov 3, 2008 | 04:04 PM
bsan1827's Avatar
Will a can of spray carb cleaner work or will I have to take everything apart. And I remember reading about the carb boot thanks for reminding me.
Old Nov 3, 2008 | 05:00 PM
I would take everything apart, I wouldn't skimp when it comes to that type of thing IMO
Old Nov 3, 2008 | 06:15 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
agreed, that spray isnt going to do the trick if the carb has dirt,gumed up or what have you. try a good clean air filter to see if it makes any differnce. also look inside the carb mouth to see if any dirt got in there and if it did then it most likely will have to come apart. imo.
SOLOLUCKY
Oct 4, 2024 09:09 PM
wannabe32
Jul 7, 2015 11:30 AM
gfl0224
Jun 27, 2015 06:52 PM
Polarisman1123
May 25, 2015 10:07 PM
Polarisman1123
May 25, 2015 10:03 PM
