Electrical System
Old Nov 3, 2008 | 06:56 PM
jimmyf-1999's Avatar
Default Electrical System
hello all.. new guy here.
I have a 2004.5 Sportsman 500 HO.. I have the 60" Glacier plow on it using the Warn 2.5 winch.
I just installed 2 55w fog lights and I am thinking about adding some more lights on it..
Questions are:
1. can I add a battery to the system to help in not killing my battery
2. can i upgrade something to charge more
3. what are the limits of the current alternator, or whatever it is call on the ATV.
Thanks for all the help..
James
PS - I would like to add: strobes, backup light.. and maybe a 12v heater (enclosure is almost done)
Old Nov 6, 2008 | 12:01 AM
wow... didn't think it was that hard of a question..
thanks, i guess [img]i/expressions/face-icon-small-sad.gif[/img]
James
Old Nov 6, 2008 | 01:08 PM
hddoperator's Avatar
I'd like to help ya but I'm not really sure of the answer. I'd like to know too,wouldn't mind adding a few more lights to mine.
Old Nov 6, 2008 | 01:20 PM
02magnum500's Avatar
Gets his share of deer.
Well most likely you have 240 Watts of output on your charging system. this number is most likely at mid to upper rpm range. The low beams are about 27 watts each and the high beam is about 50 watts and the tail lights are 8 watts. that is 62 watts if you run your low beams and tail light, then add in the fogs that you added and you are up to 172 watts. Chances are the pod and 4x4 along with other electrical components take up more watts. So, at idle the batttery light will most likely kick on if all your lights are on. Dont forget about the cooling fan, not sure on the watts for this. you can run 2 12v batteries in parallel to get double the run time, dont wire wrong or you would have 24 volts.
ReconBayou
Oct 31, 2022 05:37 PM
speedbuff
13
Nov 11, 2020 10:16 AM
Oct 10, 2015 10:20 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
lancemll88
Sep 6, 2015 03:03 AM
