trailboss 330. DEAD
Old Nov 3, 2008 | 10:21 PM
vmutt's Avatar
Default trailboss 330. DEAD
Any ideas on how to revive this beast? Its an 05, took it out one day rode fine. Next time just didnt want to turn at all. Checked battery, battery was fine. Nothing going on, no lights NADA. Had buddy check out the electrical, couldnt find anything. He replaced a few parts hoping he would pinpoint but nothing. Has anyone had this problem? Any help would be helpful.
Thanks,
Old Nov 3, 2008 | 10:25 PM
oatman98's Avatar
Did you check the engine kill switch? could be bad. unplug the wires and ohm test the switch. should have 0 ohms when in run position.
Old Nov 3, 2008 | 10:41 PM
vmutt's Avatar
This guy went thru the entire electrical wiring on this thing. Im pretty sure he checked that out. I can have him check it out, but cant get it to run at all. Thanks will check
Old Nov 3, 2008 | 10:44 PM
700 sportsman's Avatar
could be a possible CDI problem
Old Nov 3, 2008 | 10:56 PM
vmutt's Avatar
Let me check with him, to make sure what he went over, but im positive he went over eerything. Will get back to you guys
Old Nov 4, 2008 | 07:51 AM
ftwflh's Avatar
Sounds like a bad battery to me.Most the time it is the simple stuff.
Old Nov 4, 2008 | 11:20 AM
vmutt's Avatar
Battery was new. Had that checked after he did all this just to make sure.
Old Nov 4, 2008 | 07:35 PM
ftwflh's Avatar
Check the circut breaker next,then check all connections
Old Nov 5, 2008 | 12:40 AM
vmutt's Avatar
I honestly believe my mech went thru the entire electrical wiring on this thing. I can always go back and ask him, i believe he logged over 6 hours checking this quad out. Will ask and get back to you guys.
What about the stator, I have read on other post. Could that be it?
Old Nov 5, 2008 | 07:57 AM
ftwflh's Avatar
check each lead on te stator with a multimeter should be NO continuity between wires
pgamboa
Dec 24, 2023 11:52 AM
68_327_c20
Nov 25, 2023 12:26 PM
Myronh
Sep 8, 2015 11:27 AM
DM2015
Sep 7, 2015 10:36 AM
Dan Newberry
Aug 30, 2015 09:42 AM
