Hold the brake before starting?
Is there an easy way to disconnect this without disabling the brake light?
That's one thing I miss about the Jap machines with the little green button , right by your left hand.
Mine always starts easier when warm if I give it a little gas. I already know, I can either, lock or hold the brake, or put it in neutral or park, I'd rather not mess with this 15 or 20 times a day, especially when we just stop for a second to see which way we want to go.
What are we talking about here? Sportsman 90 or what? IF is the youth model with the combo brake light/starter interlock,has a small pin connector harness into brake assy that terminates into two wires. I SUPPOSE you can tie em together to eliminate holding brake to start,BUT brake light will always be on. Havent had this asked before!!
Oh sorry Old Polaris Tech, they are '08 Sportsman 400 HO and '08 Sportsman 500 EFI.
I really did'nt want to mess up the brake light circuit. I'm surprised no body else has mentioned this. My last ATV was a Yamaha and it was the same way, having to hold the brake to start but with it you could hold the brake and push the starter button with the same hand, so it was no biggie.
Unforunately, it sounds like the brake light and the starter may be on the same circuit, huh?
Hey, do you guys know if you are supposed to do this on a 1988 trail boss 250? I'm having trouble getting spark. I just bought it and only had it running once since I bought it. I'm wondering If my coil went bad or If it could be something else more simple. I hadn't even thought about applying the brake.
<div class="FTQUOTE"><begin quote>Originally posted by: Howmon
Hey, do you guys know if you are supposed to do this on a 1988 trail boss 250? I'm having trouble getting spark. I just bought it and only had it running once since I bought it. I'm wondering If my coil went bad or If it could be something else more simple. I hadn't even thought about applying the brake.</end quote></div>
no you dont need to hold the brake on those. check all your grounds before going any further
<div class="FTQUOTE"><begin quote>Originally posted by: max49
Unforunately, it sounds like the brake light and the starter may be on the same circuit, huh?</end quote></div>
[img]i/expressions/face-icon-small-happy.gif[/img] JUST another way to keep away from lawsuits I suppose if some kid was to start in gear with throttle wide open(probably has happened)! OR Feds getting tougher on atv manufacturers! There is a brake light switch and may be possible to bypass,BUT you didnt hear that from me![img]i/expressions/face-icon-small-happy.gif[/img]
Must be. I usually lock the hand brake anyway when I turn it off, but I like using one hand to turn the key and another to work the choke and the throttle.
Another reason to get EFI I guess [img]i/expressions/face-icon-small-smile.gif[/img]
Our 06 700 will start in gear without holding the brake, that's whay I was kinda worried one night when wife and I went riding and we stopped for a few minutes. I couldn't get the 850 to start back up, as it was still in high gear. So I put it in park and it fired right up, next stop I left it in gear and tried the brake before starting and it of course started. I'm guessing it must have started in 07.
