Excessive RPM in High Gear
Old Nov 5, 2008 | 02:00 AM
rachgg4's Avatar
Default Excessive RPM in High Gear
Hi there, we are new to forums and would really appreciate any help people can give. We recently purchased a 250 trail boss 2x4 and after a few times riding around the paddocks the engine started excessive reving and forward momentum in high gear only. When you back off the throttle it will start to move forward again but it sounds nasty. Do you have any ideas??
Old Nov 5, 2008 | 08:08 AM
ftwflh's Avatar
Bad belt or secondary(rear)clutch or both
Old Nov 5, 2008 | 06:35 PM
rachgg4's Avatar
Thanks for that.
Is there any chance it could be the gearbox?
Old Nov 5, 2008 | 09:07 PM
700 sportsman's Avatar
possible, but probably not
how does the belt look?
thats what I would try first IMO
Old Nov 5, 2008 | 10:02 PM
rachgg4's Avatar
The belt looks worn on one edge, checked belt tension and found it to be 1 1/8 inches
I have taken the driven clutch off to adjust belt tension, and found only one shim in there. Workshop manual says to leave at least one shim so I did only to find belt now has 1 1/2 inch deflection which looks too much.
Old Nov 5, 2008 | 10:33 PM
it's possible for the belt to stretch out
I would start by replacing belt even if it is only worn on one side, and not stretched, I would replace it IMO
Old Nov 5, 2008 | 11:05 PM
ftwflh's Avatar
replace the belt
Old Nov 6, 2008 | 12:06 AM
rachgg4's Avatar
Thank you all for your help will source a new belt and try that.
Old Nov 18, 2008 | 01:40 AM
rachgg4's Avatar
Thank you so much to those who helped with fixing the problem with our bike. My partner found the gear selecter was not properly in place when he removed the gearbox. It is now fixed and running like a dream. Thank you once again.
Old Nov 18, 2008 | 08:19 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you should have checked the secondary buttons when you had it off as there most likely starting to wear out as well.
