500 scrambler lots of noise no movement
Old Nov 5, 2008 | 07:41 PM
QUAD500123's Avatar
Default 500 scrambler lots of noise no movement
i have a 2001 scrambler 500X going over everything,replaced secondary buttons
checked spring, reasembled,new belt rode with cover off cluthes appear to be operating properly.takes off fine just doesnt seem to accelerate very well ,need a long distance for it to get up to speed,stll seems like something is wrong any help would be great.
Old Nov 5, 2008 | 08:13 PM
eggenz7's Avatar
check inside the gearcase for a stripped gear or loose chain
Old Nov 5, 2008 | 09:31 PM
QUAD500123's Avatar
sorry i changed my original message it does move just not fast
Old Nov 5, 2008 | 10:56 PM
eggenz7's Avatar
need somebody with knowledge of those clutches to find this post but i would check your distance from center of bolt on each clutch. i believe its supposed to be 10" or 10 1/2" im not sure. do a search on here and im sure you will find the distance needed. if that is off then check motor mounts to see if one is broken or loose and has let the motor shift. tranny is usually bolted in and will not move but do not unrule it either. on the other hand if the distance is correct then check the EBS one way clutch if your bike has it. some have said that the fiber bushing will wear out and cause problems. sorry i cant be more specific but i havent run across anything like that.
Old Nov 5, 2008 | 10:58 PM
Willb's Avatar
If the clutch sheaves are engaging and it is a new belt check its deflection. Hotseat has some instructions on that.
If the belt is set right-no broken mounts,etc.
Left the quad off the ground and make sure that the drivetrain is moving smoothly-no worn out bearings.
If that is ok then drain the fluid out of the tranny and see how much metal comes out and start there
Old Nov 5, 2008 | 11:02 PM
ftwflh's Avatar
Sounds like you preloaded the secondary the wrong way.should be 1/3 turn counter clockwise.
Old Nov 6, 2008 | 05:16 PM
QUAD500123's Avatar
i dont think it is the secondary wound wrong the problem is not changing no matter what i do i will check distance between shafts and see if that is the issue thanks
greg74
Sep 10, 2019 03:03 PM
Divergent12
Dec 30, 2017 08:33 PM
ronnierhino06
Nov 9, 2015 12:56 PM
stendori
Aug 14, 2015 12:57 PM
dougn85
Aug 5, 2015 07:20 AM
