3 headlight mod
Old Nov 6, 2008 | 04:24 PM
hddoperator's Avatar
Default 3 headlight mod
Well I finally got around to doing the three headlight mod on the wifes quad and let me say it's well worth the time.
I used a 12v relay instead of the diode method.It took me about an hour but I'm still moving slow from my back surgery. I'm also picky *** hell when it comes to these things so an hour ain't bad.
Now that I've done it once it shouldn't take as long when I do mine, just gotta get more shrink tube etc.
If anyone is on the fence about doing the mod I say go for it!
Thanks to everyone who has posted diagrams/directions to do this mod.
Old Nov 6, 2008 | 08:49 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
there be something to it since polaris finally got w/ the program and did it them selfs on the new bikes. to me its not since we dont ride at night very much if any.
Old Nov 6, 2008 | 09:25 PM
G.A.S.'s Avatar
Curious why you went with relay method oposed to using a diode??
Old Nov 7, 2008 | 10:57 AM
<div class="FTQUOTE"><begin quote>Originally posted by: G.A.S.
Curious why you went with relay method oposed to using a diode??</end quote></div>
So the added load is not put on the factory switch. I've heard of a few cases where the switch burnt out because of the extra load so I decided to play it safe.
I also know of alot of guys running the diode with no trouble so it's really just a personal preference.
Old Nov 7, 2008 | 11:58 PM
RticKwad's Avatar
Runs Stealth!
Does anyone notice that when you hold in your left front brake handle the headlight
beams reduce abit? I am not sure if this is did it from the factory setup or after I added the
3way light mod (Yes the bike is running).
Stendori, since you hadn't and we have the same make and model could you check yours?
Regards,
R'
Old Nov 8, 2008 | 09:07 AM
eggenz7's Avatar
they are going to dim a bit because the brake like is coming on. i would bet that a stock quad would not dim the headlights. theres more of a draw on your battery/charing system when all of your lights are going. the stator in quads are already pushing all the juice they can make. add a couple more lights to it than what its designed for and your gonna see some dimming somewhere. nothing to worry about though
Old Nov 8, 2008 | 09:50 AM
G.A.S.'s Avatar
You will also notice it dim some when the fan cycles.
Whitelx1
Oct 2, 2015 10:55 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
PrairieDog126
Sep 16, 2015 01:33 PM
