500 scrambler
Old Nov 6, 2008 | 11:20 PM
QUAD500123's Avatar
Default 500 scrambler
What does a yellow polaris primary spring actually do? Do you need to rejet when changing to this spring?Does it improve the whole power band or just take off?
Old Nov 7, 2008 | 08:04 AM
ftwflh's Avatar
To start swapping clutch components you need an understanding on how the clutch system works.EVERY part in the clutch effects another part in it.A spring change wont effect your jetting.
If you just want to charge the spring go with a Dalton black/white.This spring will work without changing the weights unless you change the secondary setting.If you use too high of a rate of spring you can put the RPM range of you motor too high and blow the engine.
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
