Polaris Ranger 6x6 twin bogging problems
Old Nov 7, 2008 | 06:35 AM
swedepowr1's Avatar
Default Polaris Ranger 6x6 twin bogging problems
Hey guys,
Need some help with a fleet of '08 Polaris Ranger 6x6 Twins. Engine bogs down very bad between 3000-3800 rpms, but can get it going down the trail if I pump the gas pedal, even get it to cruise at 45 mph. It does backfire when letting off the gas pedal, but idles great.
I've tried plugs, plug wires, injectors, coil pack, air filter, and cleaning the air throttle body, and air sensor in intake boot and no difference. It does have a handbrake engine rev limiter that acted up before, but that's anything over idle. Any ideas, please?
Old Nov 7, 2008 | 07:33 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default Newbie Polaris Ranger 6x6 twin bogging problems
does it do it in neutral as well or just on the trail. these must be efi models correct? are they in high elevation?
Old Nov 7, 2008 | 08:44 AM
Kerbbirds's Avatar
Sounds like the throttle position sensor needs re-set, have to hook it to computer to do this.
Old Nov 7, 2008 | 08:50 AM
swedepowr1's Avatar
It does it in neutral as well as in gear driving. Sea level, and yes they are EFI models.
Old Nov 7, 2008 | 09:45 AM
swedepowr1's Avatar
Is there a way to set the throttle position sensor without some sort of computer? Is there a computer out there affordable enough for part-time repair folks?
Old Nov 7, 2008 | 11:33 AM
swedepowr1's Avatar
Tried the turning the ignition key on-off-on 3 times with a "WAIT" and the "END." No codes thrown, I presume?
Old Nov 24, 2008 | 06:56 AM
swedepowr1's Avatar
Is no one else having these problems out there? 8 of 14 of these 6x6 are running like poop; same thing, bogging from lean condition, and exhaust fumes will make you pass out after gaining a severe headache (noxious)!
Old Nov 24, 2008 | 09:12 AM
Kerbbirds's Avatar
If 8 out of 14 are doing it, they must need re flashed , I'd say the dealer didn't set them up correctly, did you buy from the same dealer? Maybey they would send someone out to fix them, its got to be electronic/ computer problems.
skittero
35
Mar 1, 2019 12:39 AM
Land_shark1
Jul 10, 2015 12:53 AM
TJM
Jun 11, 2015 01:28 PM
Steven Bandemer
Jun 9, 2015 08:50 PM
kencbs
May 23, 2015 05:29 PM
