Rev Limiter Question
Old Nov 7, 2008 | 02:26 PM
Motohoppie's Avatar
Default Rev Limiter Question
I have a 2001 Polaris Sportsman 500HO 4x4
My machine is cutting out during idle, reverse and forwards gears. If I press the reverse override button it solves it.
I think I am having a electrical problem. I have no neutral or reverse lights on the pod. The reverse light doesn't even come on with the reverse override button pressed. I think the cooling fan is also not coming on.
Has anyone else had this problem?
Where should I begin my fix?
Thanks for any help.
Cutting out in Kansas
Old Nov 7, 2008 | 03:37 PM
eggenz7's Avatar
unplug the black wire from the rev limiter box. not sure where its located on your bike but its there.
Old Nov 7, 2008 | 03:51 PM
Motohoppie's Avatar
Unhooking this wire will make the cooling fan work?
Old Nov 7, 2008 | 04:01 PM
sjbr549's Avatar
follow the black wire from the switch to the fuse block thing. mine had 2 black wires on it i pulled 1 and did'nt fix it i pulled the other one and bingo
Old Nov 7, 2008 | 04:41 PM
eggenz7's Avatar
it will fix the override problem. for the fan i would check your sensor first. unplug the two wires from the sensor that is at the top of your radiator and use a short jumper wire to tie the two wires together. fan should come on. if it does then probably a faulty sensor. if it doesnt then check to make sure you have power going to the sensor and if that checks out i would say your fan is bad.
Old Nov 7, 2008 | 05:28 PM
Motohoppie's Avatar
All of these problems happened at the exact same time, so I was hoping to fix the fault.
DGNAZ
ATV Expeditions
Jun 22, 2017 04:20 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
awer1968
Sep 8, 2015 11:02 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
