95 Scrambler 400 - No low end power
Old Nov 8, 2008 | 11:08 AM
AlScrambler's Avatar
Default 95 Scrambler 400 - No low end power
the machine runs just fine at idle & once rolling, but, if I'm stopped at the bottom of a hill & go to accelerate, it has no power to try to blast up the hill or at least spin the wheels. Another example would be if I was stopped in some mud or sand & hit the gas, I don't get an instant hit of power lto break the tires loose like before, it just slowly wants to move away, but once rolling, it goes like it should with plenty of power.
Any suggestions as to what the problem may be?
Old Nov 8, 2008 | 02:13 PM
sjbr549's Avatar
sounds like a clutch or belt issue
Old Nov 8, 2008 | 06:26 PM
ftwflh's Avatar
How long have you had this Scrambler?
Old Nov 8, 2008 | 06:44 PM
I've had it for 4 yrs.
Old Nov 8, 2008 | 08:09 PM
scrambler400enoge's Avatar
Shapeshifter Rider
It's a 2 stroke what kinda lowend do you expect?I just love the midrange and topend accelleration on mine because it makes up in spades for the boggy lowend.
Old Nov 8, 2008 | 08:26 PM
I understand it's a 2 stroke, I would just like it to have the low end that it had until recently.
Thanks for the replies, any other ideas?
Old Nov 8, 2008 | 09:39 PM
ftwflh's Avatar
Check the secondary buttons if tyhey are good check the compression.Comp need to be at least 100 psi the higher the better
Cole Hadden
Jun 15, 2025 09:05 AM
scram5050
Aug 30, 2024 01:39 PM
mitchxc700
Aug 19, 2015 02:41 AM
maxjung
Jul 13, 2015 05:11 PM
Chocobamofo
Jul 10, 2015 07:46 PM
