stator check
Old Nov 8, 2008 | 09:52 PM
ben12's Avatar
Default stator check
Could someone tell me how to check the stator on a 1999 335 sportsman.I have read alot or the other problems of no fire and mine sounds like everybodys elces. No fire, new plug,replaced coil, I am not sure what a cdi is? Is it the little black box beside the coil ?
Old Nov 9, 2008 | 08:29 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
the cdi is like the brain box. most likely(just a guess) its a bad cdi more then anything. it would be nice if you could find a used one to try as it wouldnt be cheap to buy one. imo
Old Nov 9, 2008 | 09:52 AM
dave.570's Avatar
i would agree with stendori on this. just becouse last year i went through this with a sled changed the stator coils and turned out to be the cdi. anyway my manual says the primary is 0.3 ohms plus, and secondary is 5000ohms (cap) good luck
Old Nov 9, 2008 | 10:55 PM
ben12's Avatar
Where is a good place to get a cdi?
Old Nov 9, 2008 | 11:05 PM
CHECK stator specs before buying a 200 dollar CDI. Process of elimination without buying parts that maybe aren't bad! Good luck
Old Nov 9, 2008 | 11:42 PM
ben12's Avatar
I am not sure hoW to check the stator? I have a meter but I dont know where or what to hook to to check it?
Old Nov 10, 2008 | 12:05 AM
If you cant get specs from other members,I will look up Tuesday at work,BUT usually trigger coil(white and red/white wires) that plugs in to cdi should be around 97 ohms? plus or minus 20% Cant remember colors on charge coil,either red and red/black OR green,depending on models. Think should be around 440ohms resistance plus or minus 20%. Set meter to ohms and check each pair and check wires to ground,IF any wires shorting to ground,then may have found problem. Also brown is ground on Polaris.
Old Nov 10, 2008 | 12:10 AM
ben12's Avatar
Thanks I will try to figure it out.I am good on working on things but electrical is not my bag.
Old Nov 10, 2008 | 12:14 AM
NOT too many other peoples bag either! ASK any mechanic WHAT is the worst thing to repair! Guess you know the answer! Good luck
Jmuddin284
Jan 19, 2026 07:16 AM
slowgsxr97
Mar 18, 2022 03:40 AM
STLyamwar
Jul 25, 2020 04:44 AM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
