Exhaust options for 02 SP 700
Old Nov 10, 2008 | 06:22 PM
Eton70-4POS's Avatar
Default Exhaust options for 02 SP 700
Good evening,
I am looking to change out the exhaust on my 2002 Sportsman 700. I have the standard issue with a blown out exhaust flange gasket and and thinking about either going to a header style exhaust, or seeing if there is a retrofit for the dual exhaust like the newer 800s have. Any help would be greatly appreciated.
Brent
Old Nov 11, 2008 | 02:24 PM
Trukinbear's Avatar
Hi, I've changed mine over to the 800 style 2 into 1 header, and the White Brothers/Pure Polaris silencer. I love the increased low-end torque, lower noise levels (but nicer sound), etc.... But if you read other posts you'll see that there are exhaust manifold bolt issues - act proactivly and change to studs or otherwise address this problem before it manifests itself and you'll be way ahead of the game.
TB
Old Nov 11, 2008 | 08:13 PM
TB,
Thanks for the responce. Did you upgrade to the studs, or are you have the backing out issue as others are? Where did you get the studs from if you are running them? How does the noise levels compare with the new muffler and exhaust header? Thanks again.
Brent
Old Nov 11, 2008 | 08:45 PM
Raptor Man Dan's Avatar
HotSeat Performance has a true dual exhaust for the 700, and if you dont want to go that way, the sp800 2 to 1 header is a very reasonable upgrade, and your stock muffler will work with it.
Old Nov 12, 2008 | 02:17 AM
Trukinbear's Avatar
Brent, I'm experiencing this right now - wish I had read the forums first.
Old Nov 12, 2008 | 10:16 PM
TB,
What issues are you running into and what are you doing about them?
Brent
Old Nov 13, 2008 | 05:39 PM
Trukinbear's Avatar
Brent, See:
Previous post
Old Nov 18, 2008 | 12:48 AM
Trukinbear's Avatar
Ack! Polaris used non-standard thread count - the nearist fastener store couldn't match it up - isn't course or fine. :-(
mrtidy
Feb 3, 2016 05:00 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
black_thunder
Sep 22, 2015 07:59 PM
