Moose Work light
Old Nov 10, 2008 | 08:11 PM
Outback31's Avatar
Has ridden Rockhouse and Bearwallow trails.
Default Moose Work light
I just bought a cheap work light to put on the front of my 07 800. I just wanted another light up front. It came with no directions, It has only a black and white wire, no ground. I know I need to add a switch but where under the front pod would I wire it to. It is a 12v 35 watt halogen. Ihave added handwarmer's, and came with easy to follow directions. Do not want to fry anything. Thank's
Old Nov 10, 2008 | 10:15 PM
Outback31's Avatar
Hey, Old Polaris Tech, I know you can help.
Old Nov 11, 2008 | 12:01 AM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
First try it on a 12 volt battery ........The black and white wire is a little strange......
Usually the ground is made through the mounting bolt/threads...Is this metal??
I myself would run the light off the battery terminals with a relay so the full load is not through the Switch.............Caper........
Remember at idle...Your battery light may come on if your headlights/work light and fan kick in !!!
Old Nov 11, 2008 | 12:07 AM
eggenz7's Avatar
the black and white wire are just power and common. since its DC voltage it really doesnt matter which one is which. i agree with above post about the relay unless you have it on its own switch then i wouldnt worry about the relay.
hugemoth
Jul 20, 2020 03:28 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
bikedad3
Jul 2, 2015 02:15 AM
