03 sportsman shift trouble
Old Nov 10, 2008 | 10:52 PM
FORDRACING2105's Avatar
Default 03 sportsman shift trouble
My shifter linkage got out of aline with my shifter when it did this i took the linkage off of the shifter to yank it back in to place like i have been doing. It didnt move so i really yanked on it and now i have no 4wd in low or reverse what did i do now
and how do i fix the shifter linkage problem
I have tried adjusting the linkage several times it doesnt seam to help
thanks
cory
Old Nov 10, 2008 | 11:04 PM
ncriderforks's Avatar
Gear selector switch is bad....Replace it. THe issue I have is what else broke in the houseing when you pulled hard. It could be that the switch is ok and the gears are out of whack for the shift selector. They are timed so the shifter falls into place in the correct spot for each gear.
Old Nov 10, 2008 | 11:09 PM
ok so is the shifter shot since it wont stay lined up
Old Nov 10, 2008 | 11:12 PM
You'll have to pull it apert and tell us what you see. If you arn't familier then get a manual of someone who is.
Old Nov 10, 2008 | 11:21 PM
i have had it apart before it doesnt look like there is any thing wrong with it. it is like one of the shifter rods has to much travel and is able to get in front of the other piston but i dont know how it gets there it only happens from low to rev and wont come out of rev
colt1126
Aug 18, 2015 08:27 PM
Kodiak-vic
Jul 29, 2015 03:06 AM
heath legg
Jul 24, 2015 01:01 PM
ltrmc02
Jul 22, 2015 04:50 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
