POLARIS OWNERS PLEASE HELP
Old Nov 11, 2008 | 03:32 PM
crklapper's Avatar
Default POLARIS OWNERS PLEASE HELP
I OWN A 2007 POLARIS SPORTSMAN 500 EFI THE OTHER DAY I GOT IT IN A BIT TO DEEP AND MANAGED TO GET SOME WATER IN THE CRANK CASE I TOOK IT STRAIGHT HOME DRAINED THE WATER OUT (NOT VERY MUCH) AND PROCEEDED TO TRY TO START THE BIKE TO NO AVAIL HOWEVER IT COULD BE STARTED WITH JUMPER CABLES I JUST DONT KNOW IF A LITTLE WATER WOULD HAVE SCREWED THE STATOR UP OR WHAT AND I DONT HAVE A CLUE WHAT TO TRY NEXT OTHER THAN A NEW BATTERY ANY HELP WOULD BE GREATLY APPRECIATED AND YES I KNOW I SHOULDNT HAVE HAD IT IN THE WATER BUT WHAT CAN I SAY WE ALL MAKE MISTAKES
Old Nov 11, 2008 | 06:42 PM
crklapper's Avatar
is there anyway i can tell if the magneto is ruined or is there anyway to clean it im not real sure how it works but i find it hard to believe this wouldve caused all these problems
Old Nov 11, 2008 | 08:41 PM
TLC's Avatar
TLC
If the ATV can be started at all then its not the Stator. Try cleaning the pulse coil and flywheel contact points behind the recoil cover. My electric start would tun over but not start the ATV but would start with the pull rope only. Once I cleans the coil face and rust off the flywheel contact nub all was good again.
Old Nov 12, 2008 | 03:48 PM
crklapper's Avatar
thanks for the advice i was just under the impression that the stator gave the four wheeler all power and charged the battery because when you turn the lights on it will die
Old Nov 12, 2008 | 04:06 PM
TLC's Avatar
TLC
The stator is the beginning of the power source. No Stator means no power to Puse coil,CDI, ignition coil Spark plug you name it. Stators are like light bulbs, they work or they don't not much in between.
Cole Hadden
Jun 15, 2025 09:05 AM
Gtsordo
Jul 13, 2015 10:38 PM
maxjung
Jul 13, 2015 05:11 PM
Shifts
14
Jul 13, 2015 08:41 AM
Unzzy66
Jul 11, 2015 10:01 PM
