Rev Limiter Question
Old Nov 11, 2008 | 06:03 PM
Motohoppie's Avatar
Default Rev Limiter Question
I have a 2001 Polaris Sportsman 500HO 4x4
My machine is cutting out during idle, reverse and forwards gears. If I press the reverse override button it solves it.
I think I am having a electrical problem. I have no neutral or reverse lights on the pod. The reverse light doesn't even come on with the reverse override button pressed. I think the cooling fan is also not coming on.
Has anyone else had this problem?
Where should I begin my fix? I'm not looking to unhook the black wire from the CDI box. I would rather fix the problem than bypass it.
Thanks for any help.
Cutting out in Kansas
Old Nov 15, 2008 | 10:55 PM
Could possibly be one of the two switches on transmission,if not showing gear position on speedo causing false signal and triggering limiter, SPEEDO ITSELF may be bad,or limiter module when you push override button and runs ok! first check under pod for module with black wire and disconnect this wire, see if runs ok,but probably wont help gear position problem on speedo,this can be either switch or speedo as posted above,as far as fan not coming on,disconnect fan connector,check with 12 volts to see if fan works,if does then possible radiator sensor bad. Hope this helps you to get started! opt
Old Nov 18, 2008 | 07:32 PM
Motohoppie's Avatar
There was broken wire under the hood near the headlight pod. Fixed the wire it solved the problem.
DGNAZ
ATV Expeditions
Jun 22, 2017 04:20 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
awer1968
Sep 8, 2015 11:02 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
