Thin Clear Yellow Tube underside of handlebars
Old Nov 12, 2008 | 11:37 AM
OneOwl's Avatar
Default Thin Clear Yellow Tube underside of handlebars
hello, was wondering is anyone knows what tube i could be seeing if i look between the handle bars and frame by the gas tank. its clear and yellow and has a crack in it and is wet but i am unable to determine what type of fluid it is. could it be for the front break. its a dark clear yellow plastic tube which is thin. would appreciate any help if anyone knows -
thanks in advance
this is a very helpful site!
Old Nov 12, 2008 | 11:45 AM
scootergptx's Avatar
Supersock
Hired Gun!
It is the vent tube for your gas tank.
Old Nov 12, 2008 | 02:13 PM
OneOwl's Avatar
if cracked does it need to be replaced, or is it ok to leave since its a vent tube?
thanks for the response,
i appreciate it!
Old Nov 12, 2008 | 02:23 PM
Supersock
Hired Gun!
Got you PM. [img]i/expressions/face-icon-small-smile.gif[/img]
It won't cause any damage to let it go, but it could cause problems. I'd replace it now, and save being stuck on the trails. A few dollars for a new hose, 10 minutes of your time, and piece of mind.
Old Nov 12, 2008 | 06:22 PM
Wheels47's Avatar
The breather tube cracked on us and we just had a little bigger tube we placed over it and taped it until we could get a new one, we haven't had a problem yet. I would imagine you can by any type of tubing as long as it is the same size and it should work.
Old Nov 12, 2008 | 06:49 PM
OneOwl's Avatar
thanks for the responses - ill fix now
Old Nov 12, 2008 | 07:02 PM
Supersock
Hired Gun!
Don't want you to think that it's gonna explode or anything like that. It will just stall out the quad. But depending on what kind of situation you're in when that happens, it could be a bad thing.
ReconBayou
Oct 31, 2022 05:37 PM
mongeon
3) General Discussions..
Oct 6, 2015 02:27 AM
2many2ride
Sep 27, 2015 04:35 AM
zPuls3
1) Engine problems..
Sep 12, 2015 08:54 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
