660 Raptor needs new clutch
Old Nov 16, 2008 | 09:39 PM
live2ride_since1978's Avatar
Default 660 Raptor needs new clutch
I have a bored out 686 Raptor with hot cam, aftermarket exhaust, jets, etc...etc.
My clutch just went out and is slipping bad. I want a high performance clutch that will last (as I am hard on it) and works smoothly. What do you reccomend? Gyt-r? or Moose? others? Do I need a whole kit or just pieces like pressior plate, basket, springs, shifting forks, and/or inner hub? Please help quickly, I need to ride!!!
Old Nov 16, 2008 | 09:58 PM
91Warrior357's Avatar
OEM clutches, EBC, GYTR or Vitos HD IMO
Old Nov 17, 2008 | 02:55 AM
<div class="FTQUOTE"><begin quote>Originally posted by: 91Warrior357
OEM clutches, EBC, GYTR or Vitos HD IMO</end quote></div>
What about Trinity HD? which is cheaper, smoother? Just a clutch pkg or hub and basket?
Update: Opened clutch and a few of the discs were in pieces. Is this normal?
Is it worth the $450 to upgrade clutch hub and basket?
Old Nov 18, 2008 | 08:01 AM
95wolv's Avatar
A heavy duty kit will likely come with heavy duty springs, this will increase the "pull' needed at the clutch lever, but will give you a lot more grab from the clutch to put the power to the wheels. Some balance this out by only using half the heavy springs, and half the stock ones, just alternate heavy, stock, etc, around the clutch basket.
And NO, finding discs in pieces is niether normal or good, you really ARE hard on clutches, aren't you !!!!!
Old Nov 18, 2008 | 12:38 PM
Raptor Man Dan's Avatar
I went with Hinson for the basket and pressure plate, and did a Barnett Dirt Digger clutch w/ HD springs. My Raptor is similar in mods and I have yet to get it to slip.
Old Nov 19, 2008 | 12:49 AM
<div class="FTQUOTE"><begin quote>Originally posted by: 95wolv
And NO, finding discs in pieces is niether normal or good, you really ARE hard on clutches, aren't you !!!!!</end quote></div>
I am just a aggressive rider. Not a clutch maniac. I recently got it used and maybe it was already tore up.
I ordered a complete gytr kit (basket, hub, pressure plate, and clutches). When she's back, I'll give a review....thanks
STLyamwar
Jul 25, 2020 04:44 AM
black_thunder
Sep 6, 2015 04:41 PM
cdstang
Aug 31, 2015 07:52 AM
Aug 25, 2015 11:16 PM
Aug 21, 2015 01:23 PM
