Honda 250ex Wiench Conttection
Old Nov 17, 2008 | 07:26 AM
timatom125's Avatar
Default Honda 250ex Wiench Conttection
ok. i bought a plow about 4-5 years back. and i never hooked it up, and it sat and rotted behind the barn....i need to know what i need to hook up a wiench? will i have to buy another battery or can i just hook it to the one that is already on my 250ex?( 12V battery STOCK)....(Yes it pushes the snow... lol)
this is the wiench im planning on buying....
http://www.harborfreig...m/c.....umber=92860
</a>
http://www.harborfreight.com/cpi/cta...emnumber=91727
do i need any wires or something or other connections?
please respond quick.. i need to buy everything befor it starts snowing...
Old Nov 17, 2008 | 07:44 AM
JeffinTD's Avatar
Link to the winch you are talking about didn't work.
Anyway, typically the winch's contactor will be wired directly to the quad's battery, but using the winch constantly can draw the battery down.
If the winch you are looking at is intended for ATV's, it should come with the contactor, handlebar switch, and cables needed to set it up. Be very careful where you route the wires (especially the one on the positive battery post) so that they can't get smashed or vibrate and chaffe the insulation off. I like to put some convoluted split loom on the cables that go to the battery. It looks clean and professional, and gives an extra layer of protection.
Old Nov 17, 2008 | 12:56 PM
Y2daT's Avatar
had to look @ that wench it looks ok to me .....but harbor freight sells a remote controlled wench that is crap......when you winch the remote model it keeps running for a while after you relese the button,and the time it keeps running is very inconstant ,so you cant predict when it will stop ::::very dangurous::::
i have one of the remote winches installed on a bombaridier rally ....I remedied the problem by tossing the remote then removing the circut board in the winch.
then wired a push pull toggle switch to the relay switches in the winch....
i think the push button winch will work fine for you becouse it has no remote
(ps) my 60.00 remote winch has been running for over 1 yr now ,and has worked good since i tossed the remote
wendal
May 9, 2024 09:29 PM
rgjackson
Sep 17, 2015 11:21 AM
wendal
Sep 15, 2015 01:50 PM
stcspiderman
Sep 13, 2015 05:15 PM
Jason Campbell
Sep 7, 2015 02:25 PM
