300EX Jetting
Old Feb 3, 2001 | 06:28 PM
Y2K300EX's Avatar
I just put my Big Gun Exhaust back on with my dyno jet kit. I have realized that it pops on decel and there seems to be a leak where the header goes into the motor. Any answers to my problems would be greatly appreciated.
Old Feb 3, 2001 | 06:59 PM
bermbanger's Avatar
If you had the big gun on there before didn't you rejet? Or did it run right? Or did you realize you needed to rejet and just use the stock muffler?
Old Feb 3, 2001 | 10:11 PM
Y2K300EX's Avatar
I had it on before, but I took it off so I would get less wheel spin in the snow. But now with the same jetting as before it has the above mentioned problems.
Old Feb 4, 2001 | 05:29 PM
bermbanger's Avatar
Well my dg backfires after letting off the throttle at high speed.I didn't even have to rejet after a fresh bore,uni filter,dg pipe,high comp piston but my plug has a good tan look to it and the engine doesn't overheat so i don't worry about it.
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
