2000 sportsman 500
Old Nov 19, 2008 | 10:21 AM
blaine's Avatar
Default 2000 sportsman 500
Idles good starts missing at 1/3 throttle, Has good fuel, even switched carbs even though it looked good, everything ohms out-coil, trigger, and stator. tried known working cdi ,could trigger or stator ohm out properly and still cause problem ?
Old Nov 19, 2008 | 09:40 PM
Valves set at .006? Is cam exhaust lobe elliptical,not ground down? Possible for stator,coil to breakdown,usually when warm though.
Old Nov 20, 2008 | 12:17 PM
blaine's Avatar
Hey man thanks fo the tip. I already had the valve cover off and had checked the clearence. Apparently someone has adjusted the slack already because when I went back to look at it closer I noticed almost no lift. Too bad I didn't notice it the first time I looked at it.
mtdewmn
Jan 19, 2017 12:13 PM
velcro7279
Aug 24, 2015 01:15 PM
Stirling
Aug 11, 2015 07:23 AM
suzukiquadrunner1987
Aug 6, 2015 03:59 PM
