1998 Sportsman front disc brake question
Old Nov 19, 2008 | 09:51 PM
leebob's Avatar
Default 1998 Sportsman front disc brake question
My daughter was ridding my 500 and after about 3-5 miles the right front brake locked up. THis caused the AWD left tire to kick in and start spinning even though it was not in AWD. My question is it the MC or the brake caliper. Initially, i thought it was a bearing out in front in but i took both off cleaned and re-greased and put back together. Any help would be appreciated....
LeeBob
Old Nov 19, 2008 | 10:01 PM
REGREASED what bearing? If talking about in hub system,doesnt take grease,only hub fluid. If other wheel spins freely, then possibly caliper sticking?
Old Nov 19, 2008 | 11:08 PM
user493's Avatar
Moto Psycho
<div class="FTQUOTE"><begin quote>Originally posted by: old polaris tech
REGREASED what bearing? If talking about in hub system,doesnt take grease,only hub fluid. </end quote></div>
That's what I thought but I wasn't sure so I kept my mouth shut. I'm still learning this stuff.
Old Nov 20, 2008 | 12:27 AM
MECHANIKE's Avatar
it might be the hilliard locking into da hub,when only one locks,pulls like hell,feels like a locking brake.
Old Nov 20, 2008 | 03:07 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
there isnt nothing to grease. did check to see if the caliper piston want sticking out from rust/corrsion? whens the last time the hub fluid was changed?
Old Nov 22, 2008 | 09:07 AM
leebob's Avatar
Thanks, I wasn't aware it took hub fluid. I applied hi-temp grease (just like you would in a 4wd truck) to bearings in front. Turned out it was brake caliper sticking. Got it broken down now and in process of cleaning it.
Since i have applied grease instead of hub fluid, do i need to take back apart and clean off grease or should i just go ahead and apply fluid inside of eac hub??
Old Nov 22, 2008 | 10:24 AM
Clean off grease,fill with Polaris demand drive fluid(atf if in a pinch) through hole in hub at 12oclock position,about 2-3 ounces until full,let set so fluid can seep into bearings,hilliard,then turn to 4 or 8 oclock position,let drain until stops or just a trickle,then install 3/16 allen plug. ALSO hub nut in front of bearings torques to 12 foot pounds.
Old Nov 22, 2008 | 01:00 PM
leebob's Avatar
thanks, will keep you posted. Any chance the caliper will lock up again??
Old Nov 23, 2008 | 10:45 PM
leebob's Avatar
Got calipers back on ready to try out but brake system won't pump fluid to brakes. I have taken brake handle/pump apart cleaned and put back together. How do i get it to start pumping fluid to the brakes? Does it have to be primed?[img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Nov 24, 2008 | 09:25 AM
Kerbbirds's Avatar
leave the cap off and pump it, you will have to bleed all four calipers till you get the air out, just like a car.
