Yamaha Warrior
Old Nov 24, 2008 | 10:45 PM
WARRIOR360's Avatar
Default Yamaha Warrior
do these mods sound good for the warrior?
-duncan racing fat boy4 exhause system
-k&n air filter
-jet kit
-duncan racing racing cam
-Keihin 38mm PE Carb Kit
-duncan racing Clutch Kit
Old Nov 25, 2008 | 08:34 PM
91Warrior357's Avatar
yep, id rather have the edelbrock carb, and i dont know if there clutches are good or not i would assume that they are...
Old Nov 25, 2008 | 11:54 PM
WARRIOR360's Avatar
what do you think the warrior will do for top speed after these mods, mine is bored over to a 357cc. Im guessin low 70's does that sound right?
also 91warrior357 what do you think your warrior does top end, do you have stock gearing, and did the vesrah valves help?
Old Nov 26, 2008 | 02:06 PM
if you keep stock gearing youll prolly do in the 60's, warriors even with a 446 kit only do around 70ish i think, my warrior only does like 60 or so, its geared low i ride XC terrain mostly, but i think it needs at least a 14 fr sprocket cuz it goes through gears way to fast, having a lil taller gears on mine would let it pull hard for a lil longer, and the valves are just like OEM replacements there not oversized or anything, i wish i had gone with Kibblewhites instead but so far there doing good, i never ran the stock valves so im not sure how to compare
2quiker
Mar 22, 2022 08:36 PM
Sep 17, 2015 03:06 AM
Yamaha Side by Sides
Sep 8, 2015 01:43 PM
